peterandpam
Last seen: 1 month 3 weeks ago
diesel furnace replacement
I'm wondering if there is any advice as I replace an Ardic 432-DL furnace.  I'm considering either a Wallace 30G or an Espar D4 furnace.  There are two warm air outlets on the boat (galley, salon) and I'm hoping to use the existing ducting, using some sort of 90 mm to 70mm converter to make this happen.
Last seen: 19 min 47 sec ago
Wallace makes a great heater.  If I could have afforded it that is what I’d have.   I just installed a Planar furnace (4D equivalant).  Happy so far,and much cheaper than espar.   Planar is a German knockoff of the Espar and they mostly market to trucks and vans in Russia (cold there). I could have saved even more and got a Chinese knockoff but was dubious of quality (Planar had good reviews even in marine forums).    My only complaint is the thermostat wires ar a bit short, and a bit confusing to set mode of operation ( temp or %output and temp source(heater,tstat,remote sensor))
les
les
Johnnyoutdoors
Last seen: 6 days 2 hours ago
I just replaced a 12 year old Wallas heater with a new Wallas Viking air in March. I love it!
I am based in the Pacific Northwest (Seattle).
The contol is a bit different but once you get the hang of it, its easy.
I love the fact that it has an Android app to control the heater also. If f you have access to wifi, you can turn it on before you get to the boat. It tracks hours used, starts, and any fault codes.
Phone app control is Via bluetooth. I am very happy so far. It heats the boat very well, and sips fuel.
The fan is quiet and you can only hear the heated air blowing out the ducts. It also has a fan boost, which really gets the air moving.
It is installed in the rear birth, port side access area, under and behind port cockpit lazzerette.
